All-in-One HVLP Sprayer http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=53811 |
Author: | banjopicks [ Wed Dec 30, 2020 10:07 am ] |
Post subject: | All-in-One HVLP Sprayer |
Anyone tried this for waterborne finishes? Along with sawdust, I hate large compressors. |
Author: | Colin North [ Wed Dec 30, 2020 10:38 am ] |
Post subject: | Re: All-in-One HVLP Sprayer |
Fuji 3 Gold here, XPC gun, 1 mm tip (3 stages is a minimum really) Turbine's outside the sprayshop, better for noise and the filters. Enduro Var, gloss, flat, satin - don't like the look of the semi-gloss. Here's a gloss over EIR. |
Author: | banjopicks [ Wed Dec 30, 2020 10:49 am ] |
I'm sure I would love one of those but I'm thinking of the sub $100 all in one units. I'm sure I'd have to do a little more sanding and buffing but I do that anyway. |
Author: | TerrenceMitchell [ Wed Dec 30, 2020 12:25 pm ] |
I use a Fuji Mini Mite 4 with a 1mm needle for spraying Crystalac products. I don't have a ventilated booth and fire-safe equipment so all the dangerous stuff is off the table for me. The gun works well though. If I bought it again, I might consider the gravity gun instead of the pot on the bottom one. |
Author: | Colin North [ Wed Dec 30, 2020 2:14 pm ] |
I think he's talking about something like this, but it's $150 Attachment: HVLP.jpg OR this is <$100, but it's not HVLP |
Author: | Michaeldc [ Wed Dec 30, 2020 5:04 pm ] |
I use one of these with a 1.0mm tip. https://www.prpshop.it/en/ani-spray-gun ... zles_mm-05 It is an HPS gun as apposed to an HVLP but really lays down Endurovar nicely. There are also HVLP guns on this same page at a similar price point so look around. Yes, they are in Italy. I had my R150-T within a week and the price is very right for the quality! M |
Author: | Clay S. [ Wed Dec 30, 2020 11:09 pm ] |
I have the HF version of what Colin is showing above - a simple single stage turbine. It puts out a lot of material and is fine for light bodied paints and lacquers It sounds like a vacuum cleaner when it is running. The small turbine runs constantly, a small compressor runs intermittently. For something the size of a guitar you don't need a large compressor. I've used a small PC pancake compressor and a high pressure touchup gun and it has worked fine. The small size of the touchup gun puts out enough material with less overspray than a full size gun. The small portable compressor can be used for other tasks around the home and shop so has many more uses than just spraying the occasional guitar. If you are just getting into spray finishing these are what I would recommend and have never found the need to upgrade: https://www.homedepot.com/p/Porter-Cabl ... /203162815 https://www.ebay.com/itm/NEW-CUMMINS-AI ... SwaxJf7TEZ |
Author: | Clay S. [ Thu Dec 31, 2020 5:29 pm ] |
When I looked on the HF site for the turbine unit I have, I saw that it was replaced with the unit Colin posted. The one I have is a little simpler (no wheels or carry handle) but probably works about the same. Back then it was $60, and I caught a half price sale ($30) so it wasn't a bad deal. If you need something to spray stain on decks or wooden outdoor furniture it works pretty well. |
Author: | Pmaj7 [ Thu Dec 31, 2020 6:23 pm ] |
I sprayed water-based KTM-9 once out of the little sprayer Rockler had for $99 about 10 years ago. It worked okay, probably not as nice and smooth as a fancy one, but worked. Probably more level sanding needed. Pat |
Author: | ballbanjos [ Thu Dec 31, 2020 6:43 pm ] |
I have some nice spray equipment--a Fuji turbine system and Sata HVLP guns (though I mostly French Polish any more), but in all honesty, those cheap Harbor Freight door jam guns and a small compressor work pretty darned well and on the cheap. I got one of the California Air Tools quiet compressors, and it's not at all offensive to use. I use the Sata gun with it since I have one, but the Harbor Freight guns are not at all bad. Especially for the price. I have a banjo making buddy who buys them in quantity when they're on sale, and when they get too gunked up to easily clean, he tosses them and grabs another. Not eco friendly, but... Dave |
